Plane-Based Calibration for Linear Cameras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 2011
Linear or 1D cameras are used in several areas such as industrial inspection and satellite imagery. Since 1D cameras consist of a linear sensor, a motion (usually perpendicular to the sensor orientation) is performed in order to acquire a full image. In this paper, we present a novel linear method to estimate the intrinsic and extrinsic parameters of a 1D camera using a planar object. As opposed to traditional calibration scheme based on 3D-2D correspondences of landmarks, our method uses homographies induced by the images of a planar object. The proposed algorithm is linear, simple and produces good results as shown by our experiments.
inria-00523994 , version 1 (06-10-2010)
Jamil Drareni, Sébastien Roy, Peter Sturm. Plane-Based Calibration for Linear Cameras. International Journal of Computer Vision, 2011, 91 (2), pp.146-156. ⟨10.1007/s11263-010-0349-3⟩. ⟨inria-00523994⟩
106 Consultations
0 Téléchargements
