A Scheduling Algorithm for Defeating Collusion - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
By exploiting idle time on volunteer machines, desktop grids provide a way to execute large sets of tasks with negligible maintenance and low cost. Although desktop grids are attractive for cost-conscious projects, relying on external resources may compromise the correctness of application execution due to the well-known unreliability of nodes. In this paper, we consider the most challenging threat model: organized groups of cheaters that may collude to produce incorrect results. By using a previously described on-line algorithm for detecting collusion and characterizing the participant behaviors, we propose a scheduling algorithm that tackles collusion. Using several real-life traces, we show that our approach min- imizes redundancy while maximizing the number of correctly certified results.
RR-7403.pdf (975.5 Ko) Télécharger le fichier
inria-00524493 , version 1 (08-10-2010)
  • HAL Id : inria-00524493 , version 1
Louis-Claude Canon, Emmanuel Jeannot, Jon Weissman. A Scheduling Algorithm for Defeating Collusion. [Research Report] RR-7403, INRIA. 2010. ⟨inria-00524493⟩
135 Consultations
144 Téléchargements
