Resilient Workflows for High-Performance Simulation Platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Workflows systems are considered here to support large-scale multiphysics simulations. Because the use of large distributed and parallel multi-core infrastructures is prone to software and hardware failures, the paper addresses the need for error recovery procedures. A new mechanism based on asymmetric checkpointing is presented. A rule-based implementation for a distributed workflow platform is detailed.
HPCS2010final.pdf (156.25 Ko) Télécharger le fichier
inria-00524612 , version 1 (08-10-2010)
  • HAL Id : inria-00524612 , version 1
Toan Nguyen, Laurentiu Trifan, Jean-Antoine Désidéri. Resilient Workflows for High-Performance Simulation Platforms. The 2010 International Conference on High Performance Computing & Simulation (HPCS 2010), Jun 2010, Caen, France. ⟨inria-00524612⟩
121 Consultations
841 Téléchargements
