Improved complexity bounds for real root isolation using Continued Fractions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2010
We consider the problem of isolating the real roots of a square-free polynomial with integer coefficients using (variants of) the continued fraction algorithm (CF). We introduce a novel way to compute a lower bound on the positive real roots of univariate polynomials. This allows us to derive a worst case bound of $\sOB( d^6 + d^4\tau^2 + d^3\tau^2)$ for isolating the real roots of a polynomial with integer coefficients using the classic variant \cite{Akritas:implementation} of CF, where $d$ is the degree of the polynomial and $\tau$ the maximum bitsize of its coefficients. This improves the previous bound of Sharma \cite{sharma-tcs-2008} by a factor of $d^3$ and matches the bound derived by Mehlhorn and Ray \cite{mr-jsc-2009} for another variant of CF; it also matches the worst case bound of the subdivision-based solvers.
CF.pdf (224.09 Ko) Télécharger le fichier
inria-00524834 , version 1 (08-10-2010)
inria-00524834 , version 2 (09-10-2010)
inria-00524834 , version 3 (09-10-2010)
inria-00524834 , version 4 (01-06-2011)
  • HAL Id : inria-00524834 , version 4
  • ARXIV : 1010.2006
Elias Tsigaridas. Improved complexity bounds for real root isolation using Continued Fractions. [Research Report] RR2010, Aarhus Universitet. 2010. ⟨inria-00524834v4⟩
Collections
LARA
105 Consultations
99 Téléchargements
