A New Elimination Rule for the Calculus of Inductive Constructions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In Type Theory, definition by dependently-typed case analysis can be expressed by means of a set of equations — the semantic approach — or by an explicit pattern-matching construction — the syntactic approach. We aim at putting together the best of both approaches by extending the pattern-matching construction found in the Coq proof assistant in order to obtain the expressivity and flexibility of equation-based case analysis while remaining in a syntax-based setting, thus making dependently-typed programming more tractable in the Coq system. We provide a new rule that permits the omission of impossible cases, handles the propagation of inversion constraints, and allows to derive Streicher's K axiom. We show that subject reduction holds, and sketch a proof of relative consistency.
types-BarCorGreHerSac08-dep-matching.pdf (235.88 Ko) Télécharger le fichier
inria-00524938 , version 1 (29-10-2010)
Bruno Barras, Pierre Corbineau, Benjamin Grégoire, Hugo Herbelin, Jorge Luis Sacchini. A New Elimination Rule for the Calculus of Inductive Constructions. Types for Proofs and Programs, Mar 2008, Torino, Italy. pp.32-48, ⟨10.1007/978-3-642-02444-3_3⟩. ⟨inria-00524938⟩
510 Consultations
232 Téléchargements
