A case study in applying discrete control synthesis to excavator operation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Robotic and control systems are ever more complex to design, program, as well as to operate. Existing theoretical work and tool support in discrete control synthesis can be applied to improve task-level robot programming. This requires to determine patterns of tasks and objectives, which are at once domain-specific to robotics, and generic enough to cover a broad class of control systems. We illustrate such a framework by a case study concerning the interactive discrete control of tasks in an excavating system
2002-SMC-Robotic.pdf (297.83 Ko) Télécharger le fichier
inria-00525535 , version 1 (12-10-2010)
Hervé Marchand, Eric Rutten. A case study in applying discrete control synthesis to excavator operation. IEEE International Conference on Systems, Man and Cybernetics (IEEE SMC), Oct 2002, Hammamet, Tunisia. ⟨10.1109/ICSMC.2002.1175694⟩. ⟨inria-00525535⟩
84 Consultations
149 Téléchargements
