Methods and Geometry for Plane-Based Self-Calibration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
We consider the problem of camera self-calibration from images of a planar object with unknown Euclidean structure. The general case of possibly varying focal length is addressed. This problem is nonlinear in general. One of our contributions is a nonlinear approach that makes abstraction of the (possibly varying) focal length, resulting in a computationally efficient algorithm. In addition, it does not require a good initial estimate of the focal length, unlike previous approaches. As for the initialization of other parameters, we propose a practical approach that simply requires taking one image in roughly fronto-parallel position. Closed-form solutions for various configurations of unknown intrinsic parameters are provided. Our methods are evaluated and compared to previous approaches using simulated and real images. Besides our practical contributions, we also provide a detailed geometrical interpretation of the principles underlying our approach.
GurdjosSturm-cvpr03.pdf (603.32 Ko) Télécharger le fichier
inria-00525633 , version 1 (26-05-2011)
Pierre Gurdjos, Peter Sturm. Methods and Geometry for Plane-Based Self-Calibration. IEEE Conference on Computer Vision and Pattern Recognition (CVPR '03), Jun 2003, Madison, United States. pp.491-496, ⟨10.1109/CVPR.2003.1211394⟩. ⟨inria-00525633⟩
321 Consultations
317 Téléchargements
