A Method for Interactive 3D Reconstruction of Piecewise Planar Objects from Single Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
Peter Sturm
We present an approach for 3D reconstruction of objects from a single image. Obviously, constraints on the 3D structure are needed to perform this task. Our approach is based on user-provided coplanarity, perpendicularity and parallelism constraints. These are used to calibrate the image and perform 3D reconstruction. The method is described in detail and results are provided.
SturmMaybank-bmvc99.pdf (761.43 Ko) Télécharger le fichier
inria-00525674 , version 1 (30-05-2011)
  • HAL Id : inria-00525674 , version 1
Peter Sturm, Steve Maybank. A Method for Interactive 3D Reconstruction of Piecewise Planar Objects from Single Images. The 10th British Machine Vision Conference (BMVC '99), Sep 1999, Nottingham, United Kingdom. pp.265-274. ⟨inria-00525674⟩
563 Consultations
699 Téléchargements
