The SIGNAL declarative synchronous language: controller synthesis and systems/architecture design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Harel and Pnueli showed (1985) that dynamical systems are an essential in the area of computer science. In this context they are called reactive systems. Synchronous languages have been proposed as a paradigm to deal with reactive systems and develop tools for them. In this paper we introduce synchronous programming paradigm via the notion of multiclock dynamical systems and illustrate it via the SIGNAL language. We give an outline of controller synthesis in SIGNAL, and system/architecture design
2001-CDC-Signal.pdf (148.63 Ko) Télécharger le fichier
inria-00526268 , version 1 (14-10-2010)
Albert Benveniste, Patricia Bournai, Thierry Gautier, Michel Le Borgne, Paul Le Guernic, et al.. The SIGNAL declarative synchronous language: controller synthesis and systems/architecture design. 40th IEEE Conference on Decision and Control, Dec 2001, Orlando, United States. pp.3284 - 3289, ⟨10.1109/.2001.980328⟩. ⟨inria-00526268⟩
134 Consultations
264 Téléchargements
