Tiji, a Generic Trajectory Generation Tool for Motion Planning and Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Trajectory generation consists in computing a feasible trajectory between a start and a goal state-time, for a given robotic system. We presented in our previous works a trajectory generator called Tiji, geared towards complex dynamic systems subject to differential constraints. Moreover, it is able to handle a final time constraint, ie. an interval of time during which the goal state must be reached, and to provide an admissible trajectory that ends close to the goal state-time if no solution exists to connect both states. This paper is a natural extension of these works, and presents several applications of our trajectory generator. Arbitrary robotic systems may be handled. Furthermore, the control-oriented nature of Tiji and its ability to handle a final time constraint makes it a useful tool to embed into various reactive approaches (trajectory tracking, obstacle avoidance). Simulation and experimental results illustrate the different systems and navigation approaches in which Tiji has been embedded.
IROS10_0994_FI.pdf (1.37 Mo) Télécharger le fichier
poster_IROS2010.pdf (1.7 Mo) Télécharger le fichier
Format : Autre
inria-00526671 , version 1 (15-10-2010)
  • HAL Id : inria-00526671 , version 1
Vivien Delsart, Thierry Fraichard. Tiji, a Generic Trajectory Generation Tool for Motion Planning and Control. IEEE-RSJ Int. Conf. on Intelligent Robots and Systems, Oct 2010, Tapei, Taiwan. ⟨inria-00526671⟩
186 Consultations
441 Téléchargements
