Towards a True Acoustic-Visual Speech Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents an initial bimodal acoustic-visual synthesis system able to generate concurrently the speech signal and a 3D animation of the speaker's face. This is done by concatenating bimodal diphone units that consist of both acoustic and visual information. The latter is acquired using a stereovision technique. The proposed method addresses the problems of asyn- chrony and incoherence inherent in classic approaches to audiovisual synthesis. Unit selection is based on classic target and join costs from acoustic-only synthesis, which are augmented with a visual join cost. Preliminary results indicate the benefits of this approach, since both the synthesized speech signal and the face animation are of good quality.
AVSP10-AT.pdf (935.4 Ko) Télécharger le fichier
inria-00526782 , version 1 (15-10-2010)
  • HAL Id : inria-00526782 , version 1
Asterios Toutios, Utpala Musti, Slim Ouni, Vincent Colotte, Brigitte Wrobel-Dautcourt, et al.. Towards a True Acoustic-Visual Speech Synthesis. 9th International Conference on Auditory-Visual Speech Processing - AVSP2010, Sep 2010, Hakone, Kanagawa, Japan. pp.POS1-8. ⟨inria-00526782⟩
290 Consultations
172 Téléchargements
