Dynamic Fractional Resource Scheduling for HPC Workloads - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a novel job scheduling approach for homogeneous cluster computing platforms. Its key feature is the use of virtual machine technology for sharing resources in a precise and controlled manner. We justify our approach and propose several job scheduling algorithms. We present results obtained in simulations for synthetic and real-world High Performance Computing (HPC) workloads, in which we compare our proposed algorithms with standard batch scheduling algorithms. We find that our approach widely outperforms batch scheduling. We also identify a few promising algorithms that perform well across most experimental scenarios. Our results demonstrate that virtualization technology coupled with lightweight scheduling strategies affords dramatic improvements in performance for HPC workloads.
IPDPS2010-SVC.pdf (265.32 Ko) Télécharger le fichier
inria-00527068 , version 1 (18-10-2010)
Mark Stillwell, Frédéric Vivien, Henri Casanova. Dynamic Fractional Resource Scheduling for HPC Workloads. IEEE International Symposium on Parallel & Distributed Processing (IPDPS), 2010, Apr 2010, Atlanta, GA, United States. pp.1-12, ⟨10.1109/IPDPS.2010.5470356⟩. ⟨inria-00527068⟩
194 Consultations
251 Téléchargements
