An approach using wavelet transform for land cover changes detection on remote sensing data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
The paper addresses a new application of time-frequency representation in classification of non-stationary signals. It defines an approach to characterize curves describing the temporal reflectance profiles related to land-cover behavior. These curves are obtained from processing multi-resolution remote sensing data and then projected on a representation space improving discrimination between different land cover types. This approach can be applied in a scenario dedicated to the detection of land use changes caused by erosion.
Bouzidi-SETIT-2003.pdf (389.69 Ko) Télécharger le fichier
inria-00527191 , version 1 (18-10-2016)
  • HAL Id : inria-00527191 , version 1
Sonia Bouzidi, Isabelle Herlin. An approach using wavelet transform for land cover changes detection on remote sensing data. Sciences of Electronic, Technologies of Information and Telecommunications : SETIT 2003, Mar 2003, Mahdia, Tunisia. ⟨inria-00527191⟩
115 Consultations
19 Téléchargements
