Regional scale land use/land cover classification using temporal series of MODIS data at the High Taquari Basin, MS, Brazil - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
This paper describes a methodology for providing systematic land use/land cover classification on a regional scale, with specific application to the High Taquari Basin, in the state of Mato Grosso do Sul, Brazil. The methodology is based on previous work developed at INRIA by Bouzidi et al. (2000) and proposes the use of multitemporal 250m resolution surface reflectance data from the Moderate Resolution Imaging Spectroradiometer (MODIS), on board NASA's Terra satellite. This data will be coupled with higher-resolution training information in order to compute characteristic temporal MODIS reflectance profiles for each class and each band. A linear mixture model will then be applied so as to compute the proportions of each class within each MODIS pixel over areas where classification information may not be available, thus enabling the monitoring of land use/land cover over large regions such as the High Taquari Basin and its adjacencies.
Jonathan-SBSR-2005 (2).pdf (63.09 Ko) Télécharger le fichier
inria-00527213 , version 1 (08-09-2016)
  • HAL Id : inria-00527213 , version 1
Milton Jonathan, Margareth Simões Penello Meireilles, Jean-Paul Berroir, Isabelle Herlin, Heitor Luiz da Costa Coutinho. Regional scale land use/land cover classification using temporal series of MODIS data at the High Taquari Basin, MS, Brazil. Simposio Brasileiro de Sensoriamento Remoto, Apr 2005, Goiânia, Brazil. pp.579-581. ⟨inria-00527213⟩
Collections
INRIA INRIA2
101 Consultations
31 Téléchargements
