Semiclassical Propagation of Coherent States for the Hartree equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales Henri Poincaré Année : 2011
In this paper we consider the nonlinear Hartree equation in presence of a given external potential, for an initial coherent state. Under suitable smoothness assumptions, we approximate the solution in terms of a time dependent coherent state, whose phase and amplitude can be determined by a classical flow. The error can be estimated in $L^2$ by $C \sqrt {\var}$, $\var$ being the Planck constant. Finally we present a full formal asymptotic expansion.
apppCOHE12_f.pdf (360.29 Ko) Télécharger le fichier
inria-00528993 , version 1 (23-10-2010)
inria-00528993 , version 2 (09-11-2010)
inria-00528993 , version 3 (23-01-2011)
Agissilaos Athanassoulis, Thierry Paul, Federica Pezzotti, Mario Pulvirenti. Semiclassical Propagation of Coherent States for the Hartree equation. Annales Henri Poincaré, 2011, 12 (8), pp.1613-1634. ⟨10.1007/s00023-011-0115-2⟩. ⟨inria-00528993v3⟩
206 Consultations
179 Téléchargements
