inria-00529498, version 2
A POMDP Extension with Belief-dependent Rewards (Extended Version)
Mauricio Araya-López
a, 1Olivier Buffet
a, 1Vincent Thomas
b, 1François Charpillet
a, 1
N° RR-7433 (2010)
Résumé : Partially Observable Markov Decision Processes (POMDPs) model sequential decision-making problems under uncertainty and partial observability. Unfortunately, some problems cannot be modeled with state-dependent reward functions, e.g., problems whose objective explicitly implies reducing the uncertainty on the state. To that end, we introduce ρPOMDPs, an extension of POMDPs where the reward function ρ depends on the belief state. We show that, under the common assumption that ρ is convex, the value function is also convex, what makes it possible to (1) approximate ρ arbitrarily well with a piecewise linear and convex (PWLC) function, and (2) use state-of-the-art exact or approximate solving algorithms with limited changes.
- a – INRIA
- b – Université Nancy II
- 1 : MAIA (INRIA Lorraine - LORIA)
- INRIA – CNRS : UMR7503 – Université Henri Poincaré - Nancy I – Université Nancy II – Institut National Polytechnique de Lorraine (INPL)
- Domaine : Informatique/Intelligence artificielle
- Mots-clés : partially observable Markov decision processes – reward function – active sensing – piecewise linear and convex approximation
- Référence interne : RR-7433
- Versions disponibles : v1 (26-10-2010) v2 (15-12-2010)
- inria-00529498, version 2
- http://hal.inria.fr/inria-00529498
- oai:hal.inria.fr:inria-00529498
- Contributeur : Olivier Buffet
- Soumis le : Mardi 14 Décembre 2010, 16:48:53
- Dernière modification le : Mercredi 15 Décembre 2010, 11:02:27
Documents associés
Exporter
