Cryptanalysis of a Fast Encryption Scheme for Databases and of its Variant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
Stéphane Jacob
  • Fonction : Auteur
  • PersonId : 881280
Protecting the confidentiality in large databases without degrading their performance is a challenging problem, especially when encryption and decryption must be performed at the database-level or at the application-level. We here focus on symmetric ciphers for database encryption since they are the only type of ciphers with acceptable performance for most applications. We point out that stream ciphers are the adequate type of encryption schemes. We present an attack on a dedicated stream cipher proposed by Ge and Zdonic in~2007, and on a variant of this encryption scheme.
article-ieee-vep.pdf (123.22 Ko) Télécharger le fichier
inria-00530733 , version 1 (29-10-2010)
  • HAL Id : inria-00530733 , version 1
Stéphane Jacob. Cryptanalysis of a Fast Encryption Scheme for Databases and of its Variant. 2010. ⟨inria-00530733⟩
Collections
INRIA INRIA2
53 Consultations
46 Téléchargements
