Extending INET Framework for Directional and Asymmetrical Wireless Communications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper reports our work on extending the Omnet INET Framework with a directional radio model, putting a special emphasis on the implementation of asymmetrical communications. We first analyze the original INET radio model, focusing on its design and components. Then we discuss the modifications that have been done to support directional communications. Our preliminary results show that the new model is flexible enough to allow the user to provide any antenna pattern shape, with only an additional reasonable computational cost.
DMU09_embed.pdf (962.71 Ko) Télécharger le fichier
inria-00530809 , version 1 (29-10-2010)
  • HAL Id : inria-00530809 , version 1
Paula Uribe, Juan-Carlos Maureira, Olivier Dalle. Extending INET Framework for Directional and Asymmetrical Wireless Communications. ICST 3rd International Workshop on OMNeT++, ICST, Mar 2010, Torremolinos, Spain. 8p. ⟨inria-00530809⟩
138 Consultations
163 Téléchargements
