Visualizing Populated Ontologies with OntoTrix - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Benjamin Bach
  • Fonction : Auteur
  • PersonId : 881302
Gennady Legostaev
  • Fonction : Auteur
  • PersonId : 881303
Emmanuel Pietriga
Connectez-vous pour contacter l'auteur
Most tools for visualizing Semantic Web data structure the representation according to the concept definitions and interrelations that constitute the ontology's vocabulary. Instances are often treated as somewhat peripheral information, when considered at all. The visualization of instance-level data poses different but significant challenges as instances will often be orders of magnitude more numerous than the concept definitions that give them machine-processable meaning. We present a visualization technique designed to visualize large instance sets and the relations that connect them. This visualization uses both node-link and adjacency matrix representations of graphs to visualize different parts of the data depending on their semantic and local structural properties, exploiting ontological knowledge to drive the layout of, and navigation in, the visualization.
ontotrix_iswc2010.pdf (425.68 Ko) Télécharger le fichier
Format : Figure, Image
inria-00530852 , version 1 (06-11-2010)
  • HAL Id : inria-00530852 , version 1
Benjamin Bach, Gennady Legostaev, Emmanuel Pietriga. Visualizing Populated Ontologies with OntoTrix. International Semantic Web Conference (ISWC) 2010, Nov 2010, Shanghai, China. pp.85-88. ⟨inria-00530852⟩
419 Consultations
461 Téléchargements
