WCET ANALYSIS OF MULTI-LEVEL SET-ASSOCIATIVE DATA CACHES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Benjamin Lesage
  • Fonction : Auteur
  • PersonId : 881369
Damien Hardy
Isabelle Puaut
Nowadays, the presence of cache hierarchies tends to be a common trend in processor architectures, even in hardware for real-time embedded systems. Caches are used to fill the gap between the processor and the main memory, reducing access times based on spatial and temporal locality properties of tasks. Cache hierarchies are going even further however at the price of increased complexity. In this paper, we present a safe static data cache analysis method for hierarchies of non-inclusive caches. Using this method, we show that considering the cache hierarchy in the context of data caches allows tighter estimates of the worst case execution time than when considering only the first cache level. We also present considerations about the update policy for data caches.
paper.pdf (141.3 Ko) Télécharger le fichier
inria-00531218 , version 1 (02-11-2010)
  • HAL Id : inria-00531218 , version 1
Benjamin Lesage, Damien Hardy, Isabelle Puaut. WCET ANALYSIS OF MULTI-LEVEL SET-ASSOCIATIVE DATA CACHES. 9th Intl. Workshop on Worst-Case Execution Time WCET Analysis, Jun 2009, Dublin, Ireland. pp.2283. ⟨inria-00531218⟩
215 Consultations
265 Téléchargements
