Non uniform multiresolution method for optical flow and phase portrait models: environmental applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 1999
In this paper we define a complete framework for processing large image sequences for a global monitoring of short range oceanographic and atmospheric processes. This framework is based on the use of a non quadratic regularization technique for optical flow computation that preserves flow discontinuities. We also show that using an appropriate tessellation of the image according to an estimate of the motion field can improve optical flow accuracy and yields more reliable flows. This method defines a non uniform multiresolution approach for coarse to fine grid generation. It allows to locally increase the resolution of the grid according to the studied problem. Each added node refines the grid in a region of interest and increases the numerical accuracy of the solution in this region. We make use of such a method for solving the optical flow equation with a non quadratic regularization scheme allowing the computation of optical flow field while preserving its discontinuities. The second part of the paper deals with the interpretation of the obtained displacement field. For this purpose a phase portrait model used along with a new formulation of the approximation of an oriented flow field allowing to consider arbitrary polynomial phase portrait models for characterizing salient flow features. This new framework is used for processing oceanographic and atmospheric image sequences and presents an alternative to complex physical modeling techniques.
inria-00532728 , version 1 (04-11-2010)
Isaac Cohen, Isabelle Herlin. Non uniform multiresolution method for optical flow and phase portrait models: environmental applications. International Journal of Computer Vision, 1999, 33 (1), pp.29-49. ⟨10.1023/A:1008161130332⟩. ⟨inria-00532728⟩
Collections
INRIA INRIA2
37 Consultations
0 Téléchargements
