Object Based Optical Flow Estimation with an Affine Prior Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
We investigate an original method to compute the optical flow on image sequences. Instead of assuming invariance principles applied to individual pixels, this method considers objects as a whole, by constraining their total intensity during their motion. A variational implementation of this method has already been studied. We propose here a parametric implementation of this method using an affine prior model. A combined method between the variational method and the affine method is proposed in order to capture both affine components and non-affine components. Results on meteorological infrared data are presented
Fichier non déposé
inria-00532745 , version 1 (04-11-2010)
Dominique Béréziat, Isabelle Herlin. Object Based Optical Flow Estimation with an Affine Prior Model. Proceedings of the International Conference on Pattern Recognition (ICPR), Sep 2000, Barcelona, Spain. pp.1048-1051, ⟨10.1109/ICPR.2000.903725⟩. ⟨inria-00532745⟩
Collections
INRIA INRIA2
47 Consultations
0 Téléchargements
