Partitioning techniques and lumping computation for reducing chemical kinetics. APLA: an Automatic Partitioning and Lumping Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Numerical Mathematics Année : 2002
The time integration of Air Pollution Models is a difficult task due to numerical stiffness, nonlinearity and coupling between equations and implicit schemes are usually advocated. Based on the slow/fast behaviour of the chemical dynamics, reducing procedures are alternative efficient techniques leading to nonstiff systems. Reduced models are defined by a set of lumped species and algebraic constraints and their validity is related with the correct partitioning of dynamics (species and reactions). By using some axiomatic hypothesis and algebraic properties we propose in this paper an efficient partitioning technique and an algorithm in order to compute the lumping of species in an automatic way. This is applied to four atmospheric chemical mechanisms
inria-00532765 , version 1 (04-11-2010)
Rafik Djouad, Bruno Sportisse. Partitioning techniques and lumping computation for reducing chemical kinetics. APLA: an Automatic Partitioning and Lumping Algorithm. Applied Numerical Mathematics, 2002, 43 (4), pp.383-398. ⟨10.1016/S0168-9274(02)00111-3⟩. ⟨inria-00532765⟩
50 Consultations
0 Téléchargements
