Classboxes: A Minimal Module Model Supporting Local Rebinding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
Classical module systems support well the modular development of applications but do not offer the ability to add or replace a method in a class that is not defined in that module. On the other hand, languages that support method addition and replacement do not provide a modular view of applications, and their changes have a global impact. The result is a gap between module systems for object-oriented languages on one hand, and the very desirable feature of method addition and replacement on the other hand. To solve these problems we present classboxes, a module system for object-oriented languages that provides method addition and replacement. Moreover, the changes made by a classbox are only visible to that classbox (or classboxes that import it), a feature we call local rebinding. To validate the model, we have implemented it in the Squeak Smalltalk environment, and performed experiments modularising code.
Berg03a-JMLC03-Classboxes.pdf (209.61 Ko) Télécharger le fichier
inria-00533446 , version 1 (06-11-2010)
  • HAL Id : inria-00533446 , version 1
Alexandre Bergel, Stéphane Ducasse, Roel Wuyts. Classboxes: A Minimal Module Model Supporting Local Rebinding. Joint Modular Languages Conference (JMLC'03), Aug 2003, Klagenfurt, Austria. ⟨inria-00533446⟩
74 Consultations
272 Téléchargements
