Chaotic behavior analysis based on sliding bifurcations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nonlinear Analysis: Hybrid Systems Année : 2010
In this paper, a mathematical analysis of a possible way to chaos for bounded piecewise smooth systems of dimension 3 submitted to one of it's specific bifurcations, namely the sliding ones, is proposed. This study is based on period doubling method applied to the relied Poincaré maps.
DRAFTHALSlid.pdf (724.02 Ko) Télécharger le fichier
inria-00533447 , version 1 (06-11-2010)
Djamila Benmerzouk, Jean-Pierre Null Barbot. Chaotic behavior analysis based on sliding bifurcations. Nonlinear Analysis: Hybrid Systems, 2010, 4 (3), pp.503-512. ⟨10.1016/j.nahs.2009.12.001⟩. ⟨inria-00533447⟩
436 Consultations
209 Téléchargements
