Road networks with phase transitions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Hyperbolic Differential Equations Année : 2010
This paper is devoted to a hyperbolic 2–phase model for traffic flow on a network. The model is rigorously described and the existence of solutions is proved, without any restriction on the network geometry
reti.pdf (241.65 Ko) Télécharger le fichier
inria-00534876 , version 1 (10-11-2010)
  • HAL Id : inria-00534876 , version 1
Rinaldo M. Colombo, Paola Goatin, Benedetto Piccoli. Road networks with phase transitions. Journal of Hyperbolic Differential Equations, 2010, 7 (1), pp.85-106. ⟨inria-00534876⟩
127 Consultations
302 Téléchargements
