Complexity invariance of real interpretations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the field of implicit computational complexity, we are con- sidering in this paper the fruitful branch of interpretation methods. In this area, the synthesis problem is solved by Tarski's decision procedure, and consequently interpretations are usually chosen over the reals rather than over the integers. Doing so, one cannot use anymore the (good) properties of the natural (well-) ordering of N employed to bound the complexity of programs. We show that, actually, polynomials over the reals benefit from some properties that allow their safe use for complex- ity. We illustrate this by two characterizations, one of PTIME and one of PSPACE.
final.pdf (140.7 Ko) Télécharger le fichier
inria-00535784 , version 1 (12-11-2010)
Guillaume Bonfante, Florian Deloup. Complexity invariance of real interpretations. 7th Annual Conference on Theory and Applications of Models of Computation - TAMC 2010, Jun 2010, Prague, Czech Republic. pp.139-150, ⟨10.1007/978-3-642-13562-0⟩. ⟨inria-00535784⟩
135 Consultations
211 Téléchargements
