Can We Distinguish Biological Motions of Virtual Humans? Biomechanical and Perceptual Studies With Captured Motions of Weight Lifting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Perception of biological motions is a key issue in order to evaluate the quality and the credibility of motions of virtual humans. This paper presents a perceptual study to evaluate if human beings are able to accurately distinguish differences in natural lifting motions with various masses in virtual environments (VE), which is not the case. However, they reached very close levels of accuracy when watching to computer animations compared to videos. Still, quotes of participants suggest that the discrimination process is easier in videos of real motions which included muscles contractions, more degrees of freedom, etc. These results can be used to help animators to design efficient physically-based animations.
VRST2010preprint.pdf (2.54 Mo) Télécharger le fichier
inria-00535977 , version 1 (14-11-2010)
  • HAL Id : inria-00535977 , version 1
Ludovic Hoyet, Franck Multon, Taku Komura, Anatole Lécuyer. Can We Distinguish Biological Motions of Virtual Humans? Biomechanical and Perceptual Studies With Captured Motions of Weight Lifting. Symposium on Virtual Reality Software and Technology (VRST 2010), Nov 2010, Hong-Kong, Hong Kong SAR China. ⟨inria-00535977⟩
334 Consultations
110 Téléchargements
