A New Algorithm for Normal Dominance Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Dominance constraints are logical descriptions of trees. Efficient algorithms for the subclass of normal dominance constraints were recently proposed. We present a new and simpler graph algorithm solving these constraints more efficiently, in quadratic time per solved form. It also applies to weakly normal dominance constraints as needed for an application to computational linguistics. Subquadratic running time can be achieved employing decremental graph biconnectivity algorithms.
wndc.pdf (160.69 Ko) Télécharger le fichier
inria-00536536 , version 1 (18-11-2010)
  • HAL Id : inria-00536536 , version 1
Manuel Bodirsky, Denys Duchier, Joachim Niehren, Sebastian Miele. A New Algorithm for Normal Dominance Constraints. ACM-SIAM Symposium on Discrete Algorithms - SODA'2003, Jan 2004, New Orleans, Louisiana, United States. pp.59-67. ⟨inria-00536536⟩
313 Consultations
136 Téléchargements
