Bridging the Gap Between Underspecification Formalisms: Hole Semantics as Dominance Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
We define a back-and-forth translation between Hole Semantics and dominance constraints, two formalisms used in underspecified semantics. There are fundamental differences between the two, but we show that they disappear on practically useful descriptions. Our encoding bridges a gap between two underspecification formalisms, and speeds up the processing of Hole Semantics.
holes-dom.pdf (116.17 Ko) Télécharger le fichier
inria-00536542 , version 1 (16-11-2010)
  • HAL Id : inria-00536542 , version 1
Alexander Koller, Joachim Niehren, Stefan Thater. Bridging the Gap Between Underspecification Formalisms: Hole Semantics as Dominance Constraints. 10th Meeting of the European Chapter of the Association of Computational Linguistics, 2003, Budapest, Hungary. pp.195-202. ⟨inria-00536542⟩
143 Consultations
95 Téléchargements
