Automata and Logics for Unranked and Unordered Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
In this paper, we consider the monadic second order logic (MSO) and two of its extensions, namely Counting MSO (CMSO) and Presburger MSO (PMSO), interpreted over unranked and unordered trees. We survey classes of tree automata introduced for the logics PMSO and CMSO as well as other related formalisms; we gather results from the literature and sometimes clarify or fill the remaining gaps between those various formalisms. Finally, we complete our study by adapting these classes of automata for capturing precisely the expressiveness of the logic MSO.
rta2005.pdf (188.18 Ko) Télécharger le fichier
inria-00536694 , version 1 (16-11-2010)
  • HAL Id : inria-00536694 , version 1
Iovka Boneva, Jean-Marc Talbot. Automata and Logics for Unranked and Unordered Trees. 20th International Conference on Rewriting Techniques and Applications, 2005, Nara, Japan. pp.500--515. ⟨inria-00536694⟩
95 Consultations
290 Téléchargements
