The First-Order Theory of Ordering Constraints over Feature Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 2001
The system FT< of ordering constraints over feature trees has been introduced as an extension of the system FT of equality constraints over feature trees. We investigate the first-order theory of FT< and its fragments in detail, both over finite trees and over possibly infinite trees. We prove that the first-order theory of FT< is undecidable, in contrast to the first-order theory of FT which is well-known to be decidable. We show that the entailment problem of FT< with existential quantification is PSPACE-complete. So far, this problem has been shown decidable, coNP-hard in case of finite trees, PSPACE-hard in case of arbitrary trees, and cubic time when restricted to quantifier-free entailment judgments. To show PSPACE-completeness, we show that the entailment problem of FT< with existential quantification is equivalent to the inclusion problem of non-deterministic finite automata. Available at http://www.ps.uni-saarland.de/Publications/documents/FTSubTheory_98.pdf
144-411-1-PB.pdf (423.95 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00536800 , version 1 (11-06-2014)
Martin Müller, Joachim Niehren, Ralf Treinen. The First-Order Theory of Ordering Constraints over Feature Trees. Discrete Mathematics and Theoretical Computer Science, 2001, Vol. 4 no. 2 (2), pp.193-234. ⟨10.46298/dmtcs.267⟩. ⟨inria-00536800⟩
81 Consultations
851 Téléchargements
