Beta Reduction Constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
The constraint language for lambda structures (CLLS) can model lambda terms that are known only partially. In this paper, we introduce beta reduction constraints to describe beta reduction steps between partially known lambda terms. We show that beta reduction constraints can be expressed in an extension of CLLS by group parallelism. We then extend a known semi-decision procedure for CLLS to also deal with group parallelism and thus with beta-reduction constraints.
beta.pdf (383.19 Ko) Télécharger le fichier
inria-00536804 , version 1 (16-11-2010)
  • HAL Id : inria-00536804 , version 1
Manuel Bodirsky, Katrin Erk, Alexander Koller, Joachim Niehren. Beta Reduction Constraints. International Conference on Rewriting Techniques and Applications, 2001, Utrecht, Netherlands. pp.31-46. ⟨inria-00536804⟩
33 Consultations
188 Téléchargements
