On Underspecified Processing of Dynamic Semantics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
We propose a new inference system which operates on underspecified semantic representations of scope and anaphora. This inference system exploits anaphoric accessibility conditions known from dynamic semantics to decide scope ambiguities if possible. The main feature of the system is that it deals with underspecified descriptions directly, i.e. without enumerating readings.
dynamic.pdf (127 Ko) Télécharger le fichier
inria-00536810 , version 1 (16-11-2010)
  • HAL Id : inria-00536810 , version 1
Alexander Koller, Joachim Niehren. On Underspecified Processing of Dynamic Semantics. 18th International Conference on Computational Linguistics, 2000, Saarbrücken, Georgia. pp.460--466. ⟨inria-00536810⟩
38 Consultations
146 Téléchargements
