Constraint Programming in Computational Linguistics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2002
Constraint programming is a programming paradigm that was originally invented in computer science to deal with hard combinatorial problems. Recently, constraint programming has evolved into a technology which permits to solve hard industrial scheduling and optimization problems. We argue that existing constraint programming technology can be useful for applications in natural language processing. Some problems whose treatment with traditional methods requires great care to avoid combinatorial explosion of (potential) readings seem to be solvable in an efficient and elegant manner using constraint programming. We illustrate our claim by two recent examples, one from the area of underspecified semantics and one from parsing.
CP-NL.pdf (314.9 Ko) Télécharger le fichier
inria-00536829 , version 1 (16-11-2010)
  • HAL Id : inria-00536829 , version 1
Alexander Koller, Joachim Niehren. Constraint Programming in Computational Linguistics. Dave Barker-Plummer and David I. Beaver and Johan van Benthem and Patrick Scotto di Luzio. Words, Proofs, and Dialog, 141, CSLI Press, pp.95-122, 2002. ⟨inria-00536829⟩
83 Consultations
213 Téléchargements
