Adaptivity in High-Performance Embedded Systems: a Reactive Control Model for Reliable and Flexible Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Knowledge Engineering Review Année : 2010
System adaptivity is increasingly demanded in high-performance embedded systems, particularly in multimedia System-on-Chip (SoC), due to growing Quality of Service requirements. This paper presents a reactive control model that has been introduced in Gaspard, our framework dedicated to SoC hardware/software co-design. This model aims at expressing adaptivity as well as reconfigurability in systems performing data-intensive computations. It is generic enough to be used for description in the different parts of an embedded system, e.g. specification of how different data-intensive algorithms can be chosen according to some computation modes at the functional level; expression of how hardware components can be selected via the usage of a library of Intellectual Properties (IPs) according to execution performances. The transformation of this model towards synchronous languages is also presented, in order to allow an automatic code generation usable for formal verification, based of techniques such as model checking and controller synthesis as illustrated in the paper. This work, based on Model-Driven Engineering and the standard UML MARTE profile, has been implemented in Gaspard.
ker10-yu-hal.pdf (1.11 Mo) Télécharger le fichier
inria-00536883 , version 1 (18-11-2010)
  • HAL Id : inria-00536883 , version 1
Huafeng Yu, Abdoulaye Gamatié, Eric Rutten, Jean-Luc Dekeyser. Adaptivity in High-Performance Embedded Systems: a Reactive Control Model for Reliable and Flexible Design. Knowledge Engineering Review, 2010, 21 p. ⟨inria-00536883⟩
420 Consultations
312 Téléchargements
