Two-Discipline Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
A methodology for the numerical treatment of a two-objective minimization problem, possibly subject to equality constraints is proposed. Such a problem is a basic step in multidisciplinary optimization, sometimes referred to as concurrent engineering. Here, we consider the case where one criterion to be minimized, J_A , is preponderant over the second, J_B , that is, either more critical or more fragile. The problem is formulated as a parametric optimization in which the two criteria are smooth functions of a common design vector Y ∈ R^N . The numerical procedure is made in two steps.
chapter.pdf (748.74 Ko) Télécharger le fichier
inria-00537115 , version 1 (17-11-2010)
  • HAL Id : inria-00537115 , version 1
Jean-Antoine Desideri. Two-Discipline Optimization. Piotr Breitkopf and Rajan Filomeno Coelho. Multidisciplinary Design Optimization in Computational Mechanics, ISTE and John Wiley, pp.287-320, 2010, 9781848211384. ⟨inria-00537115⟩
113 Consultations
206 Téléchargements
