First and second order necessary conditions for stochastic optimal control problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Applied Mathematics and Optimization Année : 2012
In this work we consider a stochastic optimal control problem with either convex control constraints or finitely many equality and inequality constraints over the final state. Using the variational approach, we are able to obtain first and second order expansions for the state and cost function, around a local minimum. This fact allows us to prove general first order necessary condition and, under a geometrical assumption over the constraint set, second order necessary conditions are also established. We end by giving second order optimality conditions for problems with constraints on expectations of the final state.
versioninria2.pdf (463.53 Ko) Télécharger le fichier
inria-00537227 , version 1 (17-11-2010)
inria-00537227 , version 2 (25-06-2011)
  • HAL Id : inria-00537227 , version 2
Joseph Frédéric Bonnans, Francisco J. Silva. First and second order necessary conditions for stochastic optimal control problems. Applied Mathematics and Optimization, 2012, 65 (3), pp.403-439. ⟨inria-00537227v2⟩
450 Consultations
1542 Téléchargements
