Packing Square Tiles into One Texture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
This paper deals with the packing of square tiles of the same size into one texture. Texture size is constrained by the graphics hardware. In particular, width and height resolutions must be powers of two. To cover the whole texture and avoid space loss, common schemes pack a number of tiles that is a power of two. We show that numbers of tiles like 5, 13, 17, 25, 34 and others can also be reached without wasting memory. To achieve this, our scheme takes advantage of texture rotation and the wrapping capability of texture-addressing, which gives a toroidal topology to the texture space.
Mots clés
PackingTiles_eg04.pdf (373.14 Ko) Télécharger le fichier
PackingTiles_eg04.ppt (520.5 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00537457 , version 1 (18-11-2010)
  • HAL Id : inria-00537457 , version 1
Philippe Decaudin, Fabrice Neyret. Packing Square Tiles into One Texture. Eurographics (short papers), Aug 2004, Grenoble, France. pp.49--52. ⟨inria-00537457⟩
286 Consultations
638 Téléchargements
