Rendering Forest Scenes in Real-Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
Forests are crucial for scene realism in applications such as flight simulators. This paper proposes a new representation allowing for the real-time rendering of realistic forests covering an arbitrary terrain. It lets us produce dense forests corresponding to continuous non-repetitive fields made of thousands of trees with full parallax. Our representation draws on volumetric textures and aperiodic tiling: the forest consists of a set of edge-compatible prisms containing forest samples which are aperiodically mapped onto the ground. The representation allows for quality rendering, thanks to appropriate 3D non-linear filtering. It relies on LODs and on a GPU-friendly structure to achieve real-time performance. Dynamic lighting and shadowing are beyond the scope of this paper. On the other hand, we require no advanced graphics feature except 3D textures and decent fill and vertex transform rates. However we can take advantage of vertex shaders so that the slicing of the volumetric texture is entirely done on the GPU.
RealtimeForest_egsr04.pdf (7.11 Mo) Télécharger le fichier
RealtimeForest_Slides_EGSR04.ppt (3.89 Mo) Télécharger le fichier
RealtimeForest_large.mp4 (31.53 Mo) Télécharger le fichier
RealtimeForest_small.mp4 (15.33 Mo) Télécharger le fichier
divxRealtimeForest_large.avi (33.33 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00537458 , version 1 (18-11-2010)
  • HAL Id : inria-00537458 , version 1
Philippe Decaudin, Fabrice Neyret. Rendering Forest Scenes in Real-Time. EGSR04: 15th Eurographics Symposium on Rendering, Mark Ollila, Jun 2004, Norrköping, Sweden. pp.93--102. ⟨inria-00537458⟩
949 Consultations
1384 Téléchargements
