Interactive Animation of Ocean Waves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
We present an adaptive scheme for the interactive animation and display of ocean waves far from the coast. Relying on a procedural wave model, the method restricts computations to the visible part of the ocean surface, adapts the geometric resolution to the viewing distance and only considers the visible waves wavelengths. This yields real-time performances, even when the camera moves. The method allows the user to interactively fly over an unbounded animated ocean, which was not possible using previous approaches.
wavesSCA.pdf (6.35 Mo) Télécharger le fichier
combine-shipwaves.mpg (2.92 Mo) Télécharger le fichier
flyover.mpg (1.4 Mo) Télécharger le fichier
quality.mpg (2.92 Mo) Télécharger le fichier
real-time1.mpg (2.69 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
inria-00537490 , version 1 (18-11-2010)
Damien Hinsinger, Fabrice Neyret, Marie-Paule Cani. Interactive Animation of Ocean Waves. ACM-SIGGRAPH/EG Symposium on Computer Animation (SCA'02), Jul 2002, San Antonio, United States. pp.161 - 166, ⟨10.1145/545261.545288⟩. ⟨inria-00537490⟩
1769 Consultations
9546 Téléchargements
