Drawing for Illustration and Annotation in 3D - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
We present a system for sketching in 3D, which strives to preserve the degree of expression, imagination, and simplicity of use achieved by 2D drawing. Our system directly uses user-drawn strokes to infer the sketches representing the same scene from different viewpoints, rather than attempting to reconstruct a 3D model. This is achieved by interpreting strokes as indications of a local surface silhouette or contour. Strokes thus deform and disappear progressively as we move away from the original viewpoint. They may be occluded by objects indicated by other strokes, or, in contrast, be drawn above such objects. The user draws on a plane which can be positioned explicitly or relative to other objects or strokes in the sketch. Our system is interactive, since we use fast algorithms and graphics hardware for rendering. We present applications to education, design, architecture and fashion, where 3D sketches can be used alone or as an annotation of an existing 3D model.
BCD01.pdf (1.29 Mo) Télécharger le fichier
BCD01.ppt (7.54 Mo) Télécharger le fichier
BCD01_hires.mov (27.63 Mo) Télécharger le fichier
BCD01_lores.mov (5.8 Mo) Télécharger le fichier
BCD01_screen.pdf (301.37 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
inria-00537507 , version 1 (18-11-2010)
  • HAL Id : inria-00537507 , version 1
David Bourguignon, Marie-Paule Cani, George Drettakis. Drawing for Illustration and Annotation in 3D. EUROGRAPHICS, EUROGRAPHICS, Sep 2001, Manchester, United Kingdom. pp.C114--C122. ⟨inria-00537507⟩
267 Consultations
744 Téléchargements
