Controlling Anisotropy in Mass-Spring Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
This paper presents a deformable model that offers control of the isotropy or anisotropy of elastic material, independently of the way the object is tiled into volume elements. The new model is as easy to implement and almost as efficient as mass-spring systems, from which it is derived. In addition to controlled anisotropy, it contrasts with those systems in its ability to model constant volume deformations. We illustrate the new model by animating objects tiled with tetrahedral and hexahedral meshes.
BC00.pdf (584.99 Ko) Télécharger le fichier
BC00.ppt (1.25 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00537510 , version 1 (18-11-2010)
  • HAL Id : inria-00537510 , version 1
David Bourguignon, Marie-Paule Cani. Controlling Anisotropy in Mass-Spring Systems. 11th Eurographics Workshop on Computer Animation and Simulation (EGCAS), Aug 2000, Interlaken, Switzerland. pp.113--123. ⟨inria-00537510⟩
197 Consultations
587 Téléchargements
