Real-time Collision Detection for Virtual Surgery - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
We present a simple method for performing real-time collision detection in a virtual surgery environment. The method relies on the graphics hardware for testing the interpenetration between a virtual deformable organ and a rigid tool controlled by the user. The method enables to take into account the motion of the tool between two consecutive time steps. For our specic application, the new method runs about a hundred times faster than the well known orientedbounding- boxes tree method.
ca99.pdf (244.43 Ko) Télécharger le fichier
inria-00537512 , version 1 (18-11-2010)
Jean-Christophe Lombardo, Marie-Paule Cani, Fabrice Neyret. Real-time Collision Detection for Virtual Surgery. Computer Animation (CA'99), May 1999, Geneva, Switzerland. pp.82-90, ⟨10.1109/CA.1999.781201⟩. ⟨inria-00537512⟩
266 Consultations
1029 Téléchargements
