Fast Iterative Refinement of Articulated Solid Dynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 1999
A new dynamics algorithm for articulated solid animation is presented. It provides enhancements of computational efficiency and accuracy control with respect to previous solutions. Iterative refinement allows us to perform interactive animations which could be only computed off-line using previous methods. The efficiency results from managing two sets of constraints associated with the kinematic graph, and proceeding in two steps. First, the acyclic constraints are solved in linear time. An iterative process then reduces the closed loop errors while maintaining the acyclic constraints. This allows the user to efficiently trade off accuracy for computation time. We analyze the complexity and investigate practical efficiency compared with other approaches. In contrast with previous research, we present a single method which is computationally efficient for acyclic bodies as well as for mesh-like bodies. The accuracy control is provided by the iterative improvement performed by the algorithm and also from the existence of two constraint priority levels induced by the method. Used in conjunction with a robust integration scheme, this new algorithm allows the interactive animation of scenes containing a few thousand geometric constraints, including closed loops. It has been successfully applied to real- time simulations.
Fau99.pdf (490 Ko) Télécharger le fichier
ange.mov (1.41 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00537516 , version 1 (18-11-2010)
  • HAL Id : inria-00537516 , version 1
François Faure. Fast Iterative Refinement of Articulated Solid Dynamics. IEEE Transactions on Visualization and Computer Graphics, 1999, 5 (3), pp.268--276. ⟨inria-00537516⟩
80 Consultations
216 Téléchargements
