s'authentifier
version française rss feed
inria-00537522, version 1
Layered Deformable Models with Implicit Surfaces
Marie-Paule Cani (Auteur à contacter de préférence) a1
Graphics Interface (1998) -
Résumé : Several challenging problems in the animation of deformable objects can be solved by combining existing models with implicit surfaces. The latter are used as an extra layer which coats any kind of structure that moves and deforms over time. Implicit surfaces detect collisions, model local deformations, and transmit response forces to the inner structures. They also control the variations of the object's volume. We present several applications from the animation of organic shapes to the simulation of soft inelastic substances that can separate into smaller pieces or fuse into larger ones.
  • Domaine : Informatique/Synthèse d'image et réalité virtuelle
  • Commentaire : Invited paper – published under the name Marie-Paule Cani-Gascuel
  • inria-00537522, version 1
  • oai:hal.inria.fr:inria-00537522
  • Contributeur :
  • Déposé pour le compte de :
  • Soumis le : Lundi 29 Novembre 2010, 09:17:48
  • Dernière modification le : Mardi 21 Décembre 2010, 16:37:55
tous les articles de la base du CCSd...
