Local Deformation for Animation of Implicit Surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
Implicit surfaces are well suited to modelling organic forms that consist of an internal skeleton and deformable flesh smoothly blended around it. An implicit surface can represent such an object's geometric “skin” that deforms according to the motion of the skeleton. We propose a new, simple and efficient method for calculating local deformations to be applied to implicit surfaces during collisions with other objects or between different parts of one object. We discuss applications of this method to deformable object simulation, character animation and interactive sculpture.
sccg97.pdf (169.49 Ko) Télécharger le fichier
inria-00537525 , version 1 (18-11-2010)
  • HAL Id : inria-00537525 , version 1
Agata Opalach, Marie-Paule Cani. Local Deformation for Animation of Implicit Surfaces. Spring Conference on Computer Graphics (SCCG), Jun 1997, Bratislava, Slovakia. ⟨inria-00537525⟩
213 Consultations
239 Téléchargements
