An implicit formulation for precise contact modeling between flexible solids
This paper presents an implicit deformable model, based on isosurfaces of potential fields generated by skeletons, that provides elegant and unified formulations for both geometric parameters such as shape or deformation and physical properties such as rigidity. The model is especially designed to improve collision and contact processing for non-rigid objects. In particular, it generates and maintains exact contact surfaces during interactions.
can93_complete.pdf (3.15 Mo)
Télécharger le fichier
balchoc0.mpg (91.19 Ko)
Format : Figure, Image
Format : Autre
