A High-Level Language for Modeling Algorithms and their Properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Sabina Akhtar
  • Fonction : Auteur
  • PersonId : 855425
Stephan Merz
Martin Quinson
Designers of concurrent and distributed algorithms usually express them using pseudo-code. In contrast, most verification techniques are based on more mathematically-oriented formalisms such as state transition systems. This conceptual gap contributes to hinder the use of formal verification techniques. Leslie Lamport introduced PlusCal, a high-level algorithmic language that has the "look and feel" of pseudo-code, but is equipped with a precise semantics and includes a high-level expression language based on set theory. PlusCal models can be compiled to TLA+ and verified using the model checker tlc. However, in practice the use of PlusCal requires good knowledge of TLA+ and of the translation from PlusCal to TLA+ . In particular, the user needs to annotate the generated TLA+ model in order to define the properties to be verified and to introduce fairness hypotheses. Moreover, the PlusCal language enforces certain restrictions that often make it difficult to express distributed algorithms in a natural way. We propose a new version of PlusCal with the aim of overcoming these limitations, and of providing a language in which algorithms and their properties can be expressed naturally. We have implemented a compiler of our language to TLA+ , supporting the verification of algorithms by finite-state model checking.
final.pdf (247.14 Ko) Télécharger le fichier
SBMF_2010_Sabina.pdf (485 Ko) Télécharger le fichier
Format : Autre
inria-00537779 , version 1 (19-11-2010)
  • HAL Id : inria-00537779 , version 1
Sabina Akhtar, Stephan Merz, Martin Quinson. A High-Level Language for Modeling Algorithms and their Properties. 13th Brazilian Symposium on Formal Methods - SBMF'2010, Nov 2010, Natal, Brazil. ⟨inria-00537779⟩
194 Consultations
583 Téléchargements
