s'authentifier
version française rss feed
inria-00538509, version 1
SMCanvas: augmenter la boîte à outils Java Swing pour prototyper des techniques d'interaction avancées
Caroline Appert () 12, Michel Beaudouin-Lafon () a12
International Conferenceof the Association Francophone d'Interaction Homme-Machine (2006)
Résumé : This article presents SMCanvas, an extension of the Java Swing toolkit dedicated to prototyping and teaching graphical interaction. SMCanvas uses a simplified scene graph for rendering and state machines for interaction. The use of polymorphism and reification helps combine ease of use and power of expression. We describe our experience of using SMCanvas with Master level students for programming advanced interactions, and propose to evaluate user interface tools with benchmarks.
  • Domaine : Informatique/Interface homme-machine
  • inria-00538509, version 1
  • oai:hal.inria.fr:inria-00538509
  • Contributeur :
  • Soumis le : Lundi 22 Novembre 2010, 16:18:56
  • Dernière modification le : Mardi 23 Novembre 2010, 10:18:30
tous les articles de la base du CCSd...
